Transmitter Handling Tips To Maximize Precision And Proficiency
Discussion in 'Industry News' started by hgnimda, Jun 24, 2015.
By hgnimda on Jun 24, 2015 at 6:51 AM
    Two fingers on the control stick (thumb on top, index finger on the side for support) naturally enable pilots to more precisely control their inputs.
    By Dave Scott
    A proper helicopter/radio setup is certainly a distinct advantage, but nothing has proven to facilitate better flying during 1st U.S. R/C Flight School training courses as effectively as using two fingers on the control sticks and increasing spring tension in the radio to improve a pilot’s ability to precisely control the helicopter’s movements. The following article addresses optimum transmitter handling techniques while providing context to the proper uses of programmable exponential to help further optimize your heli’s handling.
    While individual opinions vary regarding the “best” transmitter handling techniques, it’s safe to say that few people have objectively compared them all. Rather, most pilots simply continue to use (and promote) whatever they have become accustomed to. But if you could compare all the different techniques, you would quickly discover that certain methods promote greater consistency and therefore, faster learning.
    For example, whenever a driving situation demands greater control and accuracy, automobile drivers naturally put both hands on the steering wheel. Helicopter pilots are similarly able to more precisely control their inputs and thus their flying when using both their thumbs and index fingers on the control sticks. Using two fingers on the controls has certainly proven instrumental during 1st U.S. R/C Flight School courses to produce the best results in the shortest amount of time. It’s important to note that this technique mainly applies to “precision” flying, e.g., hover, precision aerobatics, landing, etc. On the other hand, 3D stunt flying involves an entirely different approach to transmitter handling, not to mention flying techniques and equipment setups.
    While some of these transmitter handling techniques may feel strange at first if you did not start out this way, you should know that most pilots find them relatively easy to adopt when they prove to help get the job done with a lot less effort.
    CAUSE AND EFFECT
    Traditionally, most people learn to fly by trial-and-error or at the side of a recreational flyer/instructor, usually with very little preflight preparation. As a result, most pilots are conditioned to merely “reacting” to whatever the helicopter does. Hence, little thought is given to how they fly, or whether they are flying correctly. As a result, most flyers make many more control inputs than what is required when the maneuvers are flown optimally. Learning then slows dramatically when pilots reach their saturation point from having to make countless additional split-second decisions during their flights. A higher quantity of inputs also increases the likelihood of errors and a different result each time a maneuver is performed. These issues tend to be further magnified for pilots who fly with only their thumbs on top of the control sticks due to the unsupported thumb’s natural tendency to jerk or snap the controls (especially when the pilot is anxious or excited, such as when flying a new and/or expensive heli, flying in windy conditions, landing, etc.).
    Therefore, reactive thumbs-only flyers’ skills often plateau because their lack of consistency prevents them from making the correlation between their inputs and the responses of the heli needed to cement a solid foundation on which to build.
    Not unlike like the golfer who can’t keep his head down during his swing, but fantasizes that a new set of clubs will improve his game, many pilots end up looking to equipment to try to improve their flying. Specifically, they will often employ large amounts of radio exponential (expo) in an attempt to dampen the consequences of making too many inputs and jerking the controls.
    Thumbs-only pilots typically need large amounts of expo to soften the consequences of making jerkier inputs. Tow-finger pilots are naturally smoother, thus able to fly with less expo and therefore feel more connected to the helicopter. The trade-off for maintaining a precise correlation between the control inputs and the response of the heli with less expo is that you must be able to accurately control the size and pace of your inputs.
    THE EXPONENTIAL TRADE-OFF
    While it’s true that large amounts of expo have the potential to make flying smoother, it does not address poor technique and causes some predictability, and therefore consistency, to also be sacrificed. Explained: Anyone who has ever driven an older car with slop/play in the steering knows how much harder one has to work just to try to keep the car going straight. That’s because the slop or lag in the steering response makes it more difficult to correct deviations while they are yet small…prompting the operator to make larger corrections that often result in getting more response than was needed.
    Pilots who attempt to mask poor technique with large amounts of expo run into the same problems as the operator of an old car with an irregular control response. That is, in addition to sacrificing a direct correlation between control inputs and flight response and thus predictability, the sluggish (a.k.a., “wet noodle”) control response enables deviations to become larger before the corrections take effect, thereby prompting larger correction inputs that increase the potential for overcontrolling and the need for additional corrections. While it’s true that there are pilots who can fly precision despite using lots of expo, it takes extraordinary amounts of practice before being able to do so.
    Flying with less expo, on the other hand, is more comparable to driving a newer car with tighter steering. Specifically, it’s easier to keep the car going precisely where you want because the steering wheel corresponds directly to the response of the car and thus your inputs have an immediate effect on correcting deviations while they are still minute. Furthermore, the direct correlation between the steering wheel and the response of the car is more predictable and as a result, enables driving to become routine and eventually automatic.
    Pilots flying with less expo similarly experience a more direct correlation between their inputs/intentions and the response of the helicopter. The experience of flying a more “honest” heli therefore enables them to fly with greater precision and consistency. So, while good equipment and a reasonable amount of expo are certainly helpful, nothing helps as much as flying an honest helicopter and applying the proper inputs in the first place!
    To more precisely control the size and pace of your inputs and therefore also reduce over-controlling, place your thumbprints on top of control sticks and the tips of your index fingers on the side of the sticks near your thumbs for added support. To further improve your feel the neutral stick position, the type of control inputs you make, and to reduce the likelihood of applying unintentional inputs, increase the stick tension in your transmitter as high as possible.
    TWO-FINGER ADVANTAGE
    More than 1,500 pilots of all skill levels have attended 1st U.S. R/C Flight School. During that time, a flight training system has been developed resulting in a 99 percent solo success rate and more than 3/4 of the aerobatic students returning for more advanced training. However, even if everything else remained the same, the flight school would not be here today if not for the two-finger technique, in which pilots place their thumbs on the top of the sticks and the tips of their index fingers on the side of the sticks to steady their thumbs. If this is new to you, first get a comfortable grip on the transmitter, then place your thumbs on top of the sticks, then bring the tips of your index fingers to the side of the sticks near your thumbs while allowing your remaining fingers to come to rest wherever they are comfortable. Note that you’ll continue to control the inputs with your thumb on top of the stick, and your index finger is simply there for additional support.
    In the same way that two hands on a steering wheel improve control, supporting your thumb and the stick with your index finger will naturally enable you to apply smoother inputs, resulting in greater consistency and less over-controlling, especially in pressure situations. Most importantly, your ability to precisely manage the size and pace of your control inputs with two fingers on the sticks reduces the need for lots of expo. Consequently, you’re able to maintain the direct correlation between your control inputs and the response of the helicopter that is so vital to developing the precise inputs and timing required for precision flying.
    Furthermore, pilots using the two-finger technique enjoy the additional confidence that comes from feeling more connected to the helicopter. That is, rather than the heli just responding to inputs, there is the sense that it’s responding in ways that more closely match your exact inputs and intentions.
    Increased stick tension and the two-finger technique reinforce the correlation between control inputs and the response of the helicopter used to develop the consistent control and timing required to fly with precision. Always guard against taking any fingers off of the sticks and subsequently jabbing the controls without any ability to control the size and type of inputs made.
    ENHANCING FEEDBACK
    Increasing the stick tension in your radio as high as possible will significantly help minimize over-controlling and improve consistency by improving your feel for the types of control inputs you apply. You’re also less likely to accidently apply unintended inputs along with your intended inputs. In fact, 1st U.S. R/C Flight School has found these benefits to be so substantial that it installs stiffer after-market springs into all of its radios.
    Pilots must always guard against the bad habit of taking their fingers off of the control sticks, resulting in a tendency to take jabs at the controls and thus making it impossible to fly with consistency or precision. For obvious reasons, this tends to occur more often when using a transmitter strap or tray. Furthermore, when the transmitter is supported by a strap or tray, the pilot’s grip on the transmitter will tend to move around when applying inputs, thus making it harder to determine where the sticks are positioned since there’s no consistent grippoint to gauge the movements from. Consequently, over-controlling and applying unintended inputs (typically blamed on wind or radio glitches) occurs more frequently when using a strap and especially when using a tray. So if you must use a transmitter strap or tray, try to maintain a fixed grip on the transmitter to provide a base from which to better gauge the position of the controls, while also helping to steady your inputs and therefore reduce over controlling when tense or excited.
    THE LAST WORD
    “Practice makes perfect” applies only when it’s correct practice. The two-finger technique, not getting carried away with exponential, increased stick tension, and maintaining a fixed grip on the transmitter all enable pilots to more quickly make the correlation between their actions and the response of the helicopter, which leads to a better understanding of proper control and a solid foundation on which to build. Consider that, not unlike driving a car, when the control inputs are applied correctly to start with, the need for additional corrections may not even exist. It’s then that a pilot is able to stay ahead of the helicopter and join the ranks of elite pilots who control what a heli does rather than merely reacting to it. Good luck!
    1st U.S. R/C FLIGHT SCHOOL
    1. ScottE
      ScottE Active Member
      So .. i pinch grip !? No mention guess im a real noofa
    2. Captain
      Captain Active Member
      I nipple pinch & Use little if any expo. I keep my sticks short, throttle very soft & smooth & tension all the rest.
      I'm all thumbs. ........ but not for long. :cool:
      Im a hybrid... sorta pinch through some tricks and thumbs through others.
      Hang on tiger, Taerq is thumbs and he's no slouch with a heli
      Thumbs or not.... will work that out later. It's a good thing that I have my Nano mechanically stabilized. I tried linear mode just now, and I can actually keep the bird under control.....in high servo rate even! I originally went to expo mode (last year) because the damn thing was too squirrelly. I probably wouldn't have thought to try if I hadn't read this thread, Fred. (Fred- just because it rhymed)
      I keep my sticks as LOOSE and SMOOTH as possible. the length is medium/short and as i mentioned prior i use a pinch/thumbs technique while flying. I also like my transmitter sitting lower rather than higher up. Sort of comparative to homie pants... probably a bit lower than most.
