Hi guys
I need to know something.. Just gone trough the Brain setup for my 570 to see if the servos work. Everything seems to work very well but the cyclic servos are never calm.
First I thought its because Im in Setup mode. But even if I power the system without usb there is this servo tweeting you can hear in the video. All three cyclics are receiving some minimal inputs and moving a little little bit. Tail servo is calm but works. All movements are correct. No binding.
I dont think thats up to the servos. The fbl unit is new. Its my fist brain. But I cant imagine that its normal..
Setup is done correctly (200 HZ for cyclics). Powered on 2s over two ports (channel 2/aux & channel 3/s-rec). Rx pack voltage 7.7V. No esc plugged in to throttle channel. Brain is updated.
Please leave me some input here.
Thanks.
Help Bk Brain Help Needed
Discussion in 'The Chat Room' started by iggy, Nov 2, 2015.
