A limited Quantity of 300, A limited 300 lucky pilots.
The new RJX Vector full body version is manufactured in a limited quantity of 300 world wide. These 300 have serial numbers, and also can be customized with your name on the rotor head, body, and blades. Available in different combo packages. This new Vector 700 is the latest invention from RJX, and looks to be a serious competitor for today’s market. High quality components piece together a 3D speed machine for beginners to 3D professionals alike.
This combo includes:
Features
- Full Vector kit with green body.
- Main Blades 690mm Carbon.
- Tail blades 105mm Carbon.
- 3 x FS0521 HV servos.
- 1 x FS0521 THV tail servo.
- 1 x RX power cable for 2 cell battery.
- Blade Caddy.
- Battery straps.
- Full Carbon Fiber Frames.
- 28T and 30T Motor Pulley with 8mm – 6mm Sleeve Included.
- 30mm Full Carbon Tailboom.
- Painted 3pcs. Body.
- 12mm main shaft.
- 10mm rotor head Spindle with large Thrust Bearings.
- Molded full carbon tail fin.
- Full ball raced swash plate antirotation System
- Extra large 3 Bearings Main shaft Supports.
- Battery Slide System.
- Molded Full Carbon Landing skids.
- Extra large 20mm S3M 2 Stage Belt Driven Power Drive.
- Double support bearings and double one way in the autorotation unit.
- Motor Belt Tension System.
- Tail belt with Shock Dampener for maintaining perfect tension.
- Large tail case with 6x19x6 Bearings for output shaft.
- 4 Belt Guides and large Belt Pulleys for hardcore Tail Performance.
- Tail Servo Mount on Tailboom Holder.
- 6mm Carbon Tail Control Rod for precise Tail control.
For more information on the RJX Vector LE click here.
Notice Rjx Vector 700 3d Speed Le Combo – Limited Edition Helicopter.
Discussion in 'Industry News' started by HeliGods, Aug 29, 2014.
