Mini Protos Motor
Discussion in 'MS Heli' started by D1NO, Feb 3, 2015.
By D1NO on Feb 3, 2015 at 12:02 PM
  1. D1NO
    D1NO Member
      That KV would be a touch on the high side... I run a 13t on 1360kv motor...
    2. D1NO
      D1NO Member
      Thanks manyc ... Thought it might be a hit high, then came across a photo of someone with an 1880kv in mini p !!!
      thats probably a 4s motor... that would line up nicely...
    4. D1NO
      D1NO Member
      ..... So a touch on the high side .... Or catastrophic failure ??
      You would have to go the math... I assume 6s... You would have to run about 70% throttle
    6. D1NO
      D1NO Member
      That's what I'm thinking ... And with a castle speedy governor I can't seem to actually get %100 throttle .. Since you need room for governor overhead
    7. D1NO
      D1NO Member
      Yeah 6s
    8. D1NO
      D1NO Member
      Btw manyc ... Do you have any small pinions you're willing to part with
      You always do... running castle esc? Means you don't have free wheel which means you want 80 or above throttle
    Rent This Space
  • Pope Francis
  • Deli Lama
  • George Bush
  • Gene Simmons (aka Crash)
