Notice How Many Stick Combinations Does It Take To Fly 3d Helicopter In All Orientations
Discussion in 'The Chat Room' started by smakmeharder, Jul 3, 2014.
By smakmeharder on Jul 3, 2014 at 10:12 PM
    Ok here is one for the mathematicians. Assuming the helicopter can be put in many different positions while flying ie... flying forward, flying backward, flying on an angle, tick stock, sideways tick tocks. upside down in all orientations etc... How do we calculate how many stick combinations we have to know in order to fly all these maneuvers? Can this be calculated? If so how?
      A very tricky question, at least I thought so at first, I thought it was some crazy integral in Riemann space, but it is really just the sum of the stick positions,
      My radio has a resolution of 2^11, so the possible stick combinations is just PSC=4 x 2^11 =8192 possible stick combinations (with my radio). And that will make your heli do anything.
      • Informative Informative x 2
      • Thanks Thanks x 1
      I Knew it - I knew you would be the first to answer @simon ! .. awesome answer but just one question. Where is the number 4 derived from?
    3. ZEN RC
      ...... blink blink ........
    4. Jeff_Bradley
      Is this guy a geeeeek
      degrees of geometric freedom, each controlled by a stick ,
      1 elevator
      2 roll
      3 yaw
      4 pitch (cyclic),
      I am supposing that throttle is constant (in stunt 2), maybe an over simplification.
      simon
    6. simon
      it's also the the transition from one address (2^11,2^11,2^11,2^11) to the next address (to perform a given maneuver), the combinations would be nearly infinite
      and proud of it, but I wish I was a better pilot
      simon
      Right now I understand - well done. Another question... because the pitch can be either positive or negative making two totally different dimensions of flight, would that qualify as another position not considered and double the amount of stick combinations? (ie one negative the other positive) So taking your formula
      Total PSC = (PSC=4 x 2^11 (positive pitch)) + (PSC=4 x 2^11 (negative pitch)) = 16 384?
      This is negating the effect of transitions - at the moment anyway...
    9. feral
      Holy shiz you guys are smart I have absolutely no frikken idea what the hell all that mumbo jumbo is
      Hey @feral, if you can fly all orientations, you are doing it all without realizing it! So that make s you just as smart without any effort! lol...
    11. feral
      Cant do em all bud when all axis' s get to 45degrees she bites the dirt
      No, It's just pitch, includes both positive and negative
    13. simon
      At high speed, they are the best dirt naps
    14. feral
      I prefer the high headspeed high groundspeed crashes it just like there was 1kg of high explosive stuffed in there and crash hit the red button
    15. simon
      when it's not my machine that would cool, I could be weeping if it were me.
    16. simon
      you can really look at this in a heap of ways, I'm now thinking moves as an integral so it takes the form of some Markov chain (from the perspective of someone viewing the flight), or some sort of bifurcation diagram - check 'em both out @smakmeharder
      simon
    17. smakmeharder
      It really blows my mind, when you think of it we need to have the ability to respond with any 8192 stick positions to control any helicopter position at any point in time. That is crazy! No wonder learning to fly is so hard!
      I remember when i was learning and trying to do figure 8s in my small backyard with my blade 400. I had to focus that hard it felt like I just sat for a difficult an exam once after puting through say 3 packs. Now i know why.. With that many combinations, the neurons were carving many new paths - so it is actually mentally exhausting when you are learning. For me that became part of the addiction!
    18. smakmeharder
      I will don't worry @simon . I find this fascinating.. I don't know if anyone has ever bothered with this before!..
    19. simon
      there are so many pathways for sure, and it's the transition from one address to the next for the desired response. Crazy. I might have more of a think about this problem and see if I can get a better, more measured handle on this
