Align 800 With Ice2 Hv120
Discussion in 'Align' started by ripcurlsurf, Apr 30, 2015.
By ripcurlsurf on Apr 30, 2015 at 4:53 PM
  1. ripcurlsurf
    ripcurlsurf Member
    Hi Guys
    I just purchased a second hand 800.
    I had a question but I worked it out myself but I cant find a way to delete this thread.
    Cheers
    1. Mr Bling
      Mr Bling Active Member
      Administrators can delete this. Mr @HeliGods ?
    2. utrinque
      I fly 800 with 120A HV YEP. Second 800 has 180A HV YEP.
      Please be carefull with RPM. Even in 700 160A ESC is now a standard because 700 can burn 120 ESC if you fly very hard.
    3. ripcurlsurf
      ripcurlsurf Member
      I understand. The frame is pretty new but I purchased it second hand but it looks like the electrics was swapped.
      Im not going to fly it with the 120. Ill upgrade it to the 160 with a stronger motor.
      Thank you
    4. utrinque
      Look today I reached 192 km/h (119.3 mph) with 4.2kW ($50) Gartt 700 530kV motor and YEP 180A HV (around $200). Currents I use 780mm Align blades. I have also 810mm RJX asymmetric blades. Next time I expect >200 km/h.
      Do you need more? ;)
      Motor was not hot. Neither ESC. I can pushed it harder.
      Keep in mind Gartt makes now stronger 4.5kW motor. It has NMB bearings... smooth and quiet.
    5. HeliGods
      No harm done.. @ripcurlsurf , let me know if you want it removed. or it can stay ..
